Elaborate on why 3 phase power systems are used
Three phase power allows for less materially-intensive transmission infrastructure since all three phases will sum to ground voltage at the end of the line. This means theoretically no return lines are needed. In practice to account for unbalanced loads one slightly larger return line is used. In addition three phase power enables the use of rotating machines since when conductors are wound in loops, they create a rotating magnetic field.
