Name all the ways to to lighten a cantilevered I beam with a point load on the end. Minimize the mass of the I beam while keeping the deflection as low as possible.
Maybe some material with a good youngs modulus but with lighter density.
Other ways would be pocketing the vertical part of the i beam, tapering the i beam according to your moment/shear diagram as well.
- Vary the cross section over the length to minimize weight at the end
- Select a martial with a between-stiffness-to-weight ratio
- Optimize the cross section to have more material further away from the neutral axis
- Stack different materials up to make the beam. Have lighter material at the center and stiffer material further away from the neutral axis.
- Change the geometry by minimizing the length.
