What are important criteria for selecting microcontrollers?
When designing system block diagrams for consumer devices, the microcontroller (MCU) is a central component that integrates all software, firmware, and electrical assemblies.
  1. Performance Requirements:
    • Clock Speed: Ensure the MCU’s clock speed is sufficient for the computational tasks.
    • Processing Power: Consider whether the MCU’s CPU architecture (e.g., 8-bit, 16-bit, 32-bit) meets the performance needs.
  2. Memory:
    • Flash Memory: Sufficient non-volatile memory for the program code.
    • RAM: Enough volatile memory for data storage and processing needs during operation.
    • EEPROM: If non-volatile data storage is required.
  3. Peripheral Support:
    • I/O Ports: Adequate number and type of general-purpose input/output (GPIO) pins.
    • Communication Interfaces: Availability of necessary interfaces like UART, SPI, I2C, CAN, USB, Ethernet, etc.
  4. Development Support:
    • Development Tools: Availability of compilers, debuggers, and integrated development environments (IDEs).
Pinfigurator-Microcontroller Search Tool
