If I have a solid rod and hollow rod with the same mass and I let them roll down a ramp, which one reaches the bottom first and why?
Solid, Hollow Rod Down Ramp
When an object is rolling down a ramp, its energy is made up of three components:
𝑚𝑔ℎ=1/2𝑚𝑣^2+12𝐼𝜔^2
The first term is the potential energy; this is the energy is takes to lift the object up the ramp. This is equal to 𝑚𝑔ℎ with 𝑚m being the mass, 𝑔 the acceleration due to gravity, and ℎ the height of the ramp.
The second term is the translational kinetic energy; this is the energy it takes for the object to move down the ramp.
The third term is the rotational kinetic energy; this is the energy it takes for the object to roll. This is equal to 1/2𝐼𝜔^2, with 𝐼 being the moment of inertia (the object’s resistance to being rotated) and 𝜔 being the angular velocity.
For the hollow cylinder, the mass is placed the farthest from the center and thus 𝑟 is large, 𝐼 is large, and consequently it is slow. For the case of the solid cylinder, the mass distribution occurs more closer to the center, thus has lower 𝐼 and highest velocity.
Thus, the solid cylinder reaches the bottom first.
If you want to practice more questions like this, check out these other moment of inertia problems!
Here are some other tricky questions:
I think they should reach the bottom at the same time
Hi @Shan_L.Wang , this article helps explain why the solid rod reaches the bottom first! In the case of if they’re sliding (i.e. not rolling) then yes they would reach the bottom at the same time. You would not need to factor the moment of inertia in the case of a sliding rod.
Article Link: Rolling Race | Scientific American.
You should find that a solid object will always roll down the ramp faster than a hollow object of the same shape (sphere or cylinder)—regardless of their exact mass or diameter. This might come as a surprising or counterintuitive result! A classic physics textbook version of this problem asks what will happen if you roll two cylinders of the same mass and diameter—one solid and one hollow—down a ramp. The answer is that the solid one will reach the bottom first. In that specific case it is true the solid cylinder has a lower moment of inertia than the hollow one does. (Although they have the same mass, all the hollow cylinder’s mass is concentrated around its outer edge so its moment of inertia is higher.)
But it is incorrect to say “the object with a lower moment of inertia will always roll down the ramp faster.” It takes a bit of algebra to prove (see the “Hyperphysics” link below), but it turns out that the absolute mass and diameter of the cylinder do not matter when calculating how fast it will move down the ramp—only whether it is hollow or solid. So, in this activity you will find that a full can of beans rolls down the ramp faster than an empty can—even though it has a higher moment of inertia. (It has the same diameter, but is much heavier than an empty aluminum can.) Applying the same concept shows two cans of different diameters should roll down the ramp at the same speed, as long as they are both either empty or full. The same principles apply to spheres as well—a solid sphere, such as a marble, should roll faster than a hollow sphere, such as an air-filled ball, regardless of their respective diameters.
Cool animation from Wikipedia
Just a note for everyone since this confused me a bit at first:
The “moment of inertia” in the rotational kinetic energy equation above is a completely different thing from the “second moment of area” / “second moment of inertia”. This is also different from “second polar moment of area”.
The “moment of inertia” above, is a resistance to rotational motion. Think spinning / rolling stuff. You could think of it as the equivalent to mass in the angular equations of motion. All its equations have mass (I think).
The “second moment of inertia” describes the distribution of cross-sectional area compared to an axis. It relates to the shape. This is the term that is used to calculate bending stress given Moment applied and distance from neutral axis (stress = Mc / I). A higher value means more resistant to bending. The “second polar moment of inertia” is the same thing but for torsional deformation and stress. This is the term used to calculate torsional stress given torque applied and radius (stress = T * r / J)
Wiki links:
List of moment of inertia equations
List of second moment of inertia
List of second polar moment of inertia
I was reviewing this problem, and there is one more important assumption that needs to be listed.
From our original solution:
PE = KE
(Eq 1) mgh=1/2mv^2+1/2Iω^2
If mass (M doesn’t change, and mass moment of inertia (I) changes, why do we conclude that velocity is increasing? Mathematically, you can solve this by increasing the angular velocity and keeping the linear velocity the same (or decrease). There are two unknown variables, but only one equation.
After a little research, the reason we can assume that both linear and angular velocity increase is because we assume that the object rolls without slipping. The distance it moves forward (x) must match the distance it has unrolled along its circumference (r*θ). Taking the time derivative gives you the relationship between angular and linear velocity:
x = r * θ
dx/dt = d(r * θ)/dt
dx/dt = r* d(θ)/dt (radius is a constant, can be pulled out of the derivative)
(Eq 2) v = r * ω
Because of this second equation, we can say that v and ω are directly proportional to each other. Therefore, if mass moment of inertia is going up (from Equation 1), both velocity and angular velocity need to be going down to compensate.
