How do you choose the number of layers in a PCB?
Solution
The number of PCB layers should be determined based on circuit complexity, signal integrity needs, space constraints, power/ground considerations, cost, and manufacturing capabilities. Complex circuits benefit from more layers, while high-speed designs benefit from additional signal layers. More layers provide better routing and reduce interference. Separate power/ground planes aid power distribution and grounding. However, more layers increase cost.
