Top Electrical Engineering Interview Questions
Hardware engineering roles span multiple specialities, but here’s a list of a couple of the verified most asked interview questions by companies such as Apple, NVIDIA, Tesla, and more!
Software Engineering - Many FAANG hardware roles expect you to be proficient at coding. Here are some common questions:
Analog Design - Fundamental analog design along with physics-based questions are common:
What are the differences between MOSFETs and Bi-Polar Junction Transistors?
What are the advantages & disadvantages between a buck converter and a LDO?
Embedded Software/Systems - For embedded systems, knowing your communication protocols and being familiar with hardware platforms is crucial!
Digital Design - Digital design interviews can vary depending on where you are. For example, Qualcomm is likely to ask leetcode style questions, while Broadcom is likely to ask Verilog:
Board Level Design - Knowing PCB fundamentals and design trade-offs is crucial:
Signal Processing - Communications and signal processing will grill you on your fundamentals:
