Design a circuit that performs a bit shift operation on a multi-bit input (din) and outputs the shifted bits one at a time to a single-bit output (dout). The shifting should commence when the input enable signal (din_en) goes high, regardless of previous shifts. If all bits have been shifted, the output should be 0. Activate the reset (resetn) to treat the input value as 0. The input value remains 0 until the input enable signal triggers the shifting operation again.
Solution
Verilog
module model #(parameter DATA_WIDTH = 16) (
input clk, // Clock input
input resetn, // Active-low reset input
input [DATA_WIDTH-1:0] din, // Input data
input din_en, // Input enable signal
output logic dout // Output data
logic [DATA_WIDTH-1:0] temp; // Temporary variable for shifting
always @(posedge clk) begin
if (!resetn) begin // Reset is active
temp <= 0; // Set temporary variable to 0
end else if (din_en) begin // Input enable signal is high
temp <= din; // Start shifting by assigning input to temporary variable
end else begin
temp <= temp >> 1; // Shift temporary variable to the right by 1 bit
end
end
assign dout = temp[0]; // Assign the least significant bit of the temporary variable to the output
endmodule
