What are six ways to reduce cantilever beam deflection?
Fun fact: This is one of the most common technical questions for mechanical engineers. You’ll often see variations of this question phrased in different ways (i.e. case studies, design trade-offs, etc.). Understanding fundamentals well will pay dividends! :slight_smile:
Wall-Mounted Cantilever Beam, Point Load (Apple)
Check out these other top mechanical enginering interview questions!
The deflection of a cantilevered beam depends on four factors: load, length, material of beam, and cross-sectional shape.
  1. Load: How much force is applied? This can be in the form of multiple point or distributed loads applied (P)
  2. Length: Length of the beam (L)
  3. Material: Represents the modulus of elasticity - a unit of measurement of an object’s resistance to elastic (non-permanent) deformation (E)
  4. Cross-Sectional Shape: Represents the area moment of inertia - a geometrical propery of a cross-section that reflects how its area is distributed about a certain axis (I)
General Form:
Deflection = \frac{PL}{EI}
By looking at the equation, you can manipulate each variable in the numerator & denominator to reduce deflection:
  1. Reduce the load (P)
  2. Decrease the overall length (L)
  3. Material selection through using materials with a higher modulus of elasticity (E), like steel or composites that are stiffer.
  4. Change the cross-sectional shape (i.e. rectangle or I-beam if applied load induces bending moment and shear stresses) (I)
  5. Increase the beam depth - area moment of inertia of the beam’s cross-section is proportional to the cube of the depth.
  6. For cantilever beams, add structural reinforcements like braces/trusses.
Now that you know how to reduce cantilever beam deflection, try out this flagpole problem or other common technical interview questions.
